Steps need to follow to use the existing rundeck configuration from EC2 instance to Docker image
Hi ,
Currently, we have rundeck server running on EC2 Instances. I am trying to place the configuration files from rundeck server to EFS mount . Planning to copy files from /etc/rundeck and /etc/var/rundeck/ to EFS folders . Can my docker rundeck image can refer the existing configuration mounted to EFS , which includes LDAP and database configurations. what are all the steps that I need to follow to acheive this usecase .
Hi Sankaran, take a look at this approach to use EFS volumes as volume in your docker-compose.
Thanks . But Question is whether can i copy the below files from rundeck server which is running on EC2 instances to EFS
rpm -ql rundeck
/etc/rc.d/init.d/rundeckd
/etc/rundeck
/tmp/rundeck
/usr/bin/rd-acl
/var/lib/rundeck
/var/lib/rundeck/.ssh
/var/lib/rundeck/bootstrap
/var/lib/rundeck/bootstrap/rundeck-3.0.20-20190408.war
/var/lib/rundeck/cli
/var/lib/rundeck/cli/ant-1.8.3.jar
/var/lib/rundeck/cli/ant-jsch-1.8.3.jar
/var/lib/rundeck/cli/ant-launcher-1.8.3.jar
/var/lib/rundeck/cli/commons-beanutils-1.9.3.jar
/var/lib/rundeck/cli/commons-cli-1.0.jar
/var/lib/rundeck/cli/commons-codec-1.10.jar
/var/lib/rundeck/cli/commons-collections-3.2.2.jar
/var/lib/rundeck/cli/commons-httpclient-3.0.1.jar
/var/lib/rundeck/cli/commons-lang-2.6.jar
/var/lib/rundeck/cli/commons-logging-1.2.jar
/var/lib/rundeck/cli/converter-jackson-2.2.0.jar
/var/lib/rundeck/cli/dom4j-2.1.1.jar
/var/lib/rundeck/cli/guava-24.1.1-jre.jar
/var/lib/rundeck/cli/jackson-annotations-2.8.0.jar
/var/lib/rundeck/cli/jackson-core-2.8.11.jar
/var/lib/rundeck/cli/jackson-databind-2.8.11.2.jar
/var/lib/rundeck/cli/jaxen-1.1.6.jar
/var/lib/rundeck/cli/jna-4.1.0.jar
/var/lib/rundeck/cli/jna-platform-4.1.0.jar
/var/lib/rundeck/cli/jsch-0.1.55.jar
/var/lib/rundeck/cli/jsch.agentproxy.connector-factory-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.core-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.jsch-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.pageant-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.sshagent-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.usocket-jna-0.0.9.jar
/var/lib/rundeck/cli/jsch.agentproxy.usocket-nc-0.0.9.jar
/var/lib/rundeck/cli/log4j-1.2.17.jar
/var/lib/rundeck/cli/okhttp-3.6.0.jar
/var/lib/rundeck/cli/okio-1.11.0.jar
/var/lib/rundeck/cli/protobuf-java-3.5.1.jar
/var/lib/rundeck/cli/retrofit-2.2.0.jar
/var/lib/rundeck/cli/rundeck-core-3.0.20-20190408.jar
/var/lib/rundeck/cli/rundeck-storage-api-3.0.20-20190408.jar
/var/lib/rundeck/cli/rundeck-storage-conf-3.0.20-20190408.jar
/var/lib/rundeck/cli/rundeck-storage-data-3.0.20-20190408.jar
/var/lib/rundeck/cli/snakeyaml-1.17.jar
/var/lib/rundeck/data
/var/lib/rundeck/exp
/var/lib/rundeck/exp/webapp
/var/lib/rundeck/libext
/var/lib/rundeck/libext/cache
/var/lib/rundeck/libext/rundeck-copyfile-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-flow-control-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-git-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-jasypt-encryption-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-job-state-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-localexec-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-object-store-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-orchestrator-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-script-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-source-refresh-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-stub-plugin-3.0.20-20190408.jar
/var/lib/rundeck/libext/rundeck-upvar-plugin-3.0.20-20190408.jar
/var/lib/rundeck/logs
/var/lib/rundeck/repository
/var/lib/rundeck/repository/artifacts
/var/lib/rundeck/repository/installedPlugins
/var/lib/rundeck/var
/var/lib/rundeck/var/tmp
/var/lib/rundeck/var/tmp/pluginJars
/var/lib/rundeck/work
/var/log/rundeck
/var/rundeck/projects
And map rundeck docker image to map the EFS mount . Will it work ?
waiting for the reply . just to make some decision internally /
Hi Sankaran, the container can map the filesystem content using the method of my first answer. Alternatively, if you want to copy files to/from containers consider using the docker cp command. Take a look at this.
Regards.
